Alan,
Do you have something like "TAGA_=" set up in your parametric
data file for the first I/O point? When the small dialog pops up prompting
for first address, is preset in the address edit box or is it
empty? If the value is present, does just hitting OK proceed correctly or do
you have to reenter the value?
"alanhenthorne" wrote in message
news:4321438.1092848872840.JavaMail.jive@jiveforum1.autodesk.com...
> Is there a way to stop from getting the PLC address prompt. I formated
TAG_A in the DAT file so getting the prompt for address is not required.
