AutoCAD Electrical Forum
PLC Paremetric Build ACADE 2004
1 REPLY 1
alanhenthorne
167 Views, 1 Reply
Is there a way to stop from getting the PLC address prompt. I formated TAG_A in the DAT file so getting the prompt for address is not required.
1 REPLY 1
in reply to: alanhenthorne
Alan, Do you have something like "TAGA_=" set up in your parametric data file for the first I/O point? When the small dialog pops up prompting for first address, is preset in the address edit box or is it empty? If the value is present, does just hitting OK proceed correctly or do you have to reenter the value? "alanhenthorne" wrote in message news:4321438.1092848872840.JavaMail.jive@jiveforum1.autodesk.com... > Is there a way to stop from getting the PLC address prompt. I formated TAG_A in the DAT file so getting the prompt for address is not required.
”Boost
