Yes - NO need for PLC.dat file , I started using the PLC database editor to create our OEM electronic modules.
However I would like to report a problem creating / inserting the graphic user styles ( #6 for instance) with the OEM modules:
- After copying/renaming and modifiying the HP1*.dwg view files to the new style HP6*.dwg in the Referenced symbol lybrary JIC125. The inserted module does not show all the terminals as they were modified, only the TOP TERMINAL view is ok.
NOTE: I ignore the PLC database editor warning about the missing BMP images of the new style, selecting "GO anyway"
if you see the attached files, no screw terminal are there, however they keep appearing in the model space when I insert the module ( see attached BMP)
After checking Style6 selection and files search path in the PLC editor. I do not find the reason for this. Any suggestion?
