AutoCAD Electrical General Discussion
Member
0 Kudos
Post 1 of 3
PLC Parametric Build files
112 Views, 2 Replies
12-02-2003 04:15 AM
In the VIA version I was able to set a variable in the .env to look on the server for the .dat files, I don't see how to do that in the AcadE version.
-Jacques
*Autodesk, Inc\
Post 2 of 3
Re: PLC Parametric Build files
12-02-2003 05:52 AM in reply to: jbenoit
Jacques
    To point to a new location for
the plc.dat files, you need to add a path to the AutoCAD support paths.  I
do not recall there ever being a path in the env file for this, it has always
been accomplished through the general AutoCAD support paths.  If you remove
the files from your local system, add their location as an AutoCAD support path,
and you should be ready to go.  To verify that the program is finding the
information in the correct location, when you go to insert your first PLC card,
look in the upper right hand corner of the main selection dialog.  It will
give you the location it is finding the main PLC.DAT file.  I hope this
helps.
Sincerely,
Jared Bunch
Technical Support Specialist
Autodesk, Inc
In
-Jacques
Member
0 Kudos
Post 3 of 3
Re:
12-02-2003 08:29 PM in reply to: jbenoit
Jared, I am sorry, you are correct.
By the way, good to see you are still in tech support, we have spoken a few times in the past.
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
