AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
PLC Module, adding or removing spaces, breaks...
2 REPLIES 2
cbenner
902 Views, 2 Replies
Hi,...
Once I have placed a PLC Module from the default catalog (not a custom job), and have inserted it with various spaces and/or breaks.... is there any way to edit this to add more spaces or remove unwanted spaces?  Would a simple "block edit" be the way to go?
2 REPLIES 2
PatMurnen_Adsk
in reply to: cbenner
You can use the Stretch PLC Module command to add or remove spacing. This command is on the Schematic tab > Edit Components panel under the Scoot flyout. There is also a Split PLC to add breaks later. You cannot put a module back together again once a break has been added though.
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Autodesk, Inc.
”Boost
