Hi,...
Once I have placed a PLC Module from the default catalog (not a custom job), and have inserted it with various spaces and/or breaks.... is there any way to edit this to add more spaces or remove unwanted spaces? Would a simple "block edit" be the way to go?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by PatMurnen_Adsk. Go to Solution.
You can use the Stretch PLC Module command to add or remove spacing. This command is on the Schematic tab > Edit Components panel under the Scoot flyout. There is also a Split PLC to add breaks later. You cannot put a module back together again once a break has been added though.
Thanks, that's good to know.
Chris Benner
