I was wondering if it was possible to have the builder insert two modules on the same ladder, for instance two 1734-OB8 modules?
I haven't looked too much into this but everyhing I have seen so far is that the PLC IO Utility will jump to the next ladder per module.
Thanks!
Solved by wcrosby0404. Go to Solution.
Nevermind, i figured this out. Under Module Placement "Same Ladder Only if Module Fits" in the Main Speadsheet to PLC IO Utility.
Kind of emberresing how easy that was when I got the chance to look, ha
Does this feature still work in 2016? I am unable to get modules to move to the second ladder.
