AutoCAD Electrical General Discussion
conrad.rohrer
Message 1 of 7 (350 Views)
PLC I/O Utility - trim on spare TB
350 Views, 6 Replies
11-28-2012 06:48 AM
I'm curious if there is functionality that I can add to the PLC I/O Utility import spreadsheet that would trim the rung to the left/right of a spare I/O point Terminal Block symbol.
Many thanks for feedback.
testsubject
Message 2 of 7 (346 Views)
Re: PLC I/O Utility - trim on spare TB
11-28-2012 07:17 AM in reply to: conrad.rohrer
If you leave the rest of the row blank, you should get the desired result.
(Nothing in DXTAG, DXDESC, DXBLK, DXLOC)
Bob Hanrahan
Ace User since 1998
Valued Contributor
electricman1
Message 3 of 7 (342 Views)
11-28-2012 08:56 AM in reply to: conrad.rohrer
If you are talking about a common TB and not an I/O point TB. Editing the plc spacing in the "PLC Database Editor" may help. For example, edit the "Spacing Factor" to offset the common TB so it will not fall on the rung line. Add 0.875 on the common TB and 1.125 on the terminal after the common TB.
Also, check out this site: www.racklayout.com  This site has an application for creating the Excel spreadsheet.
conrad.rohrer
Message 4 of 7 (332 Views)
11-28-2012 10:18 AM in reply to: conrad.rohrer
To further clarify what I'm after, I've attached a .docx with screenshots.
I did try leaving the other columns blank (DxTAG, DxDESC, etc.) but this did not trim the wire.
testsubject
Message 5 of 7 (327 Views)
11-28-2012 11:27 AM in reply to: conrad.rohrer
Conrad,
I see what you are doing now.
Since you are using a standard terminal block, it is behaving as it should. Right off the bat, I would suggest creating a terminal with only one termination (X1TERM01) located on the right side of the terminal. The problem with that is when you later on want to add a connection the terminal will not break the wire on the left. After the PLC Utility has finished, do a project wide Swap Block to change it back to the standard terminal. Not the best solution, but not too painless.
Bob Hanrahan
Ace User since 1998
Product Support
zalant
Message 6 of 7 (282 Views)
12-05-2012 11:03 PM in reply to: testsubject
The following blog post appears to offer up the functionality you're seeking, Conrad.
http://myacade.blogspot.in/2012/04/auto-trim-wires-from-plc-io-utility.html
Please give it a shot and post back here whether or not it does what you're hoping.  Bob, if you could please throw in your opinion of the method, that would also help out greatly and would be appreciated by all others who might find this forum thread.
Zac Travis
conrad.rohrer
Message 7 of 7 (268 Views)
12-06-2012 06:22 AM in reply to: zalant
Yeah, I've seen this option also.
I still prefer adding a reference only arrow with the terminal block and instructing the users to trim.
It's low tech, but less prone to other problems.
As you've suggested, I've added this to the Product Enhancement link you've provided.
Thanks for your help.
Conrad
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
