Alan,
The symbol that you list below is one of the stand-alone, single I/O point
symbols, not one that is used in creating a parametrically built-up, I/O
module. The symbols you probably want to change are in your jic1 or jic125
library under names like HP?xxxx.dwg and VP?xxx.dwg where the "?" is a "1"
for "style one", "2" for style two, and so on. There are about 32 parametric
symbols per graphical style.
thanks,
Nate.
wrote in message news:4861609@discussion.autodesk.com...
Hello.
I'm very new to Autocad Electrical without any formal (or at all) training.
I'm using AE 2006.
I'm bringing in PLC modules but don't like the placement of the
descriptions, or the size or any of the text. Following the help file I
attempted to change the size of the text by modifying the symbol library. I
also went in manually and attempted to change the text size on each library
symbol (PLCIOI1T.dwg
etc.). This changes nothing when I insert a new module. I did this in
both the JIC1 and the JIC125 Libraries.
I know I can change the text size, position, justification manually after
the module is inserted, but this is very time consuming and i'm sure there
is a better way to go about it.
So my question is, how can i rearrange the position of the text, text size,
justification etc. prior to inserting the module.
Any help at all is appreciated.
Alan
