AutoCAD Electrical General Discussion
liamharris
Message 1 of 4 (166 Views)
PLC Database Multiple User Changes
166 Views, 3 Replies
07-03-2013 12:59 AM
I have been doing some corrections and alterations to the PLC Database (through both the Microsoft Access file on our server, and the PLC Database File Editor). All the changes made on the MA file (located in our server) applies to all the users on this server, but any changes made through the PLC Database File Editor only apply to the system of the user making the changes.
Is there a way to make the changes made on the PLC Database File Editor apply to all the other user's AutoCAD on the server?
Thanks in advanced for any help!
Valued Contributor
TomTom111
Message 2 of 4 (141 Views)
Re: PLC Database Multiple User Changes
07-03-2013 08:33 AM in reply to: liamharris
Hello liamharris,
as you found, the PLC MA file is one way to make changes to PLC schematics. To make the changes through the database editor, you wil have to copy the MA file you are editing on your local machine and replace the one on the server.
This is exctly what i do now with our company, and everything from the PLC database, Footprint drawings for panel layouts, schematic drawings, and even the Icon menus for both are kept up to date using this method.
I use "synctoy" to make these changes as simple as possible.
If you would like to know more on the procedures and locations to include in syncs to make this work, please let me know and i would be more than happy to assist you.
--Best of luck
Thomas Walls
CADMASTER TECHNOLOGIES, LLC
www.cadmastertech.com
Thomas Walls | AutoCAD Electrical 2013
liamharris
Message 3 of 4 (136 Views)
07-03-2013 08:39 AM in reply to: TomTom111
Hi TomTom111,
Thanks for the fast response!
I had assumed it was that, as it is the same for our Icon Menu also. I will let you know if I need any more help; but I reckon I will be able to sort it from here :smileyhappy:
Thanks once again.
Liam
Valued Contributor
electricman1
Message 4 of 4 (114 Views)
07-04-2013 05:59 AM in reply to: liamharris
Another method is to have your machine set to edit the database on the shared network and edit it there. The Access database should allow this. What you can do is add a "z_" (or other) in front off the modules not ready for release. This will indicate an in-process status. Then delete the "z_" indicator text when finished.
I also recommend restricting some users to read only file access. I recommend if working with a large group of users. This will help keep the honest people from causing trouble.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
