Ok, I'm not sure why you didn't get the error message. If you are able to
reproduce it, please let me know. The reason I asked if you wanted this
adjustment for just this one module, or would this be something you might
want for all the modules, is because people often get confused with the fact
that the values in the Module Box Dimensions are dimension overrides for the
module that you are editing, and the Style Box Dimensions are the dimensions
that will apply to all modules that do not have any overrides defined. So
if this was a change you wanted to apply to all modules, you would want to
make changes to the Style Box Dimensions (reached by clicking the Style Box
Dimensions button found in the main PLC Database File Editor dialog).
Mike
wrote in message
news:5788313@discussion.autodesk.com...
I think that the only thing that is different between what happened to you,
and what happened to me is that I didn't get an error message. It allowed
the single value, but did nothing when I inserted the module.. Right now,
I'm not willing to reinstall ACADE. I don't think my boss would appreciate
it 🙂 As far as your question about using this on the other modules. I'm
not sure. If it was something I wanted to do, I'd just match your default
values, and enter them. It was just a minor issue, but I wanted to post it
in case anyone else was having the problem.
