AutoCAD Electrical Forum
PLC Database Editor
6 REPLIES 6
TomTom111
603 Views, 6 Replies
PLC Database Editor
I am adding a new PLC module for a schematic.
There are inputs and outputs on the same physical device.
I am putting two terminals with module info on the icon so i can display the info for the input and output.
When I break the module at the second module info terminal point, it will add another tag for that, wich overwrites the origional tag number, with a tag looking something like the attached image...
This is with the tag box left blank for the second module info terminal.
My question is this-
Is there a way to make the tag for these PLCs blank, so I do not get the resulting image?
--Thank You
Thomas Walls
CADMASTER TECHNOLOGIES, LLC
www.cadmastertech.com
6 REPLIES 6
electricman1
in reply to: TomTom111
Looks like you may be using a "Module Info, No Terminal" option instead of a  "Terminal Point Wire Left" at the start of the break point. The "Module info...." options are usually reserved for the very first Terminal Type only. When breaking a module the child reference tag link is the standard attribute.
TomTom111
in reply to: electricman1
Thank you electricman1 for your reply.
I am purposly using this "module info terminal point wire left" so i can show a description on the second block for a description to show it is not a digital input which is the fist half of the device.
I am going to play with it more, and will report back with any viable solutions.
--Thanks again
Thomas Walls
Tee.Dee
You could create your own terminal type by copying the module info one but  instead of having the 'TAG' attribute it would have the "TAG_1" attribute in its place.
Let me know if you need any further help in doing this.
TomTom111
in reply to: Tee.Dee
I did not think of that Tee.Dee, Thanks!
I've never tried this, so if I run into a bump in the road, i wil definitely let you know.
--Thanks again
Thomas Walls
TomTom111
Worked like a charm Tee.Dee!
I copied the "Module info terminal point wire left" DWG, and deleted the TAG attribute completly. The origional tag still appears, and now there's no overlapping text.
--I owe you one, thanks.
Thomas Walls
Tee.Dee
No worries, glad to help!
”Boost
