Where are the settings stored for the PLC Database Editor?
I have had to create some additional blocks in order to create new PLC cards. I then checked on other computers accessing the shared database to verify they worked properly. The new image file created for the new PLC style was visible and the new cards were able to be inserted. When I try to demontrate how the new blocks were added to the settings, I recieved an error stating there are terminal types not currently defined. I do not recieve the error on my PC so I suspect the settings are still local.
There are two images below for reference.
Thanks.
When using the PLC database file editor, it should say what database it edits, like here:
The database location was removed from the posted image instead of blanking out some of the path as you did. The database is in a shared location and the cards can be inserted by all PC,s, but only one PC can edit the card. It acts like the “settings” are still stored locally on the PC which originally created them.
Thanks.
