AutoCAD Electrical Forum
PLC componet tag - can It be Family/Sheet#/Vgrid/Hgrid
7 REPLIES 7
Message 1 of 8
ken.coulter
638 Views, 7 Replies
ACADE 2006 I have included a drawing.
1. How do I set this up so the PLC tag gets displayed like the component tags? I want the PLC tag to be PLC0303F (The sheet number does not get displayed). I only get PLC03F. Our setup is for componets is family/Sheet#/V grid/H grid. Components tags work just fine.
2. When the module is broken, the tag does not display correctly either.
7 REPLIES 7
Message 2 of 8
in reply to: ken.coulter
Ken, Is this for a parametrically built PLC module? I believe that the Tag
format for these is actually set up in the PLC Module Builder Database. I've
included a screen shot where this is defined. You can edit the plc database
directly if you need to do a lot of edits but you should make a backup copy
first just in case.
Pat Murnen
wrote in message news:5539831@discussion.autodesk.com...
Message 3 of 8
ken.coulter
Thanks, Pat it worked great.
The PLC database file editor is handy tool.
Message 4 of 8
CAD-ICE
I know this is an old thread but I have problems following our customer demand for tag format when tagging parametric plc units. The customer wants to tag for instance digital input modules according to following:
 -6D051 where
6 =%A (Section)
D =FAMILY
05= sheet no.
1  = Line reference
As can be seen on the attached image I´m not getting the correct result by changing the TAG format in the plc database editor. I have also tried %A%D%S%N but either way I´m not getting the correct result.
Any comments appreciated.
Regards, Gary
Message 5 of 8
testsubject
in reply to: CAD-ICE
Gary,
%F is the family variable. Try that instead.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 6 of 8
CAD-ICE
in reply to: testsubject
Hello Bob and thank´s for the hint.
One thing I´m not clear on is if I use the family attribute, where can I define the default Tag-character for the family in this case PLC. If I use the family attribute, %F the module is tagged with nothing that is, I get correct values in for the section, page no. and line reference but nothing for for %F ??
Help...
Regards, Gary
Message 7 of 8
testsubject
I did not want to leave you hanging. My ability to help is pretty limited right now because I do not have access to ACE. Maybe one of the other users here can chime in.
Bob Hanrahan
Ace User since 1998
Message 8 of 8
CAD-ICE
Thank´s again Bob. Hope somone else is following this thread.
Regards, Gary
”Boost
