poushag,
If you go into PLC Database File Editor and select the Settings button you
should see a dialog that looks like the attachment. In the grid in this
dialog you can select a cell in the Block File Name column and click the
View DWG button. This will show you a view of the block that will be placed
when a terminal with the given Unique Description is used in a module. I
think the information in this grid, showing the block name and the unique
descriptions might give you the information you are looking for. Notice
that the block names will change based on the Style that you select. I
think this should help you also in figuring out which block(s) to edit.
Also, if you click the Browse button in this dialog when you are in a cell
in the Block File Name column, it should take you right to where the block
is located. Hope this helps.
Mike
wrote in message news:5786734@discussion.autodesk.com...
Version 2008 SP1
I use the Spreadsheet to PLC I/O utility to build drawings of PLC modules
(such as 1794-IB16) with one break in the middle. The result is each module
in two columns with PLC attributes INST, LOC, & TAG_1 coming in sightly
above the second column. However, we must relocate these attributes (and
doing it manually on hundreds of pages after the build is not acceptable).
There are many PLC terminal types and I have been trying to figure out which
HP1*.DWG file to edit. Looking in the PLC Database Editor has not helped.
When I right click and select 'edit terminal' most of the terminal types
available for selection have a question mark instead of a graphic. Even if
the graphics showed up, they wouldn't be any help since the DWG file names
don't show anywhere in the 'select terminal information' dialog. All I can
tell from here is that the block I want to edit is probably going to be a
'Module Info Input I/O point wire left' type. But I am no closer to
figuring out which DWG file to edit.
So I quit attempting to figure out which block was being used through the
PLC DB and tried to look into the PLC module build process.
After building the PLC module, exploding it separates everything into
individual objects so I get no clues there. Even if I enter LOGFILEON and
watch the command window during the subsequent build, it still doesn't list
the DWG files used to assemble the module so I have no help there either.
(I know it prompts that output description attributes can be moved by
scooting but that didn't work - I need to be able to move only the three
attributes listed - everything else is perfectly in place.) Is there an
external log file I can browse to find this info? Or some other way to
figure this out? Could some of this stuff be hard-coded in the wdio.lsp
file?
Any help would be appreciated but I suspect this may only be answered by one
of the Autodesk gurus...
Thanks.
