AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Pin Order From Pinlist
2 REPLIES 2
264 Views, 2 Replies
Why is it that the pins insert backward when I use the list to select them?
If I insert a relay contact and pick the parent coil, they insert in the correct order. If I select from the list, the pins reverse.
Is this a bug?
Jeff
2 REPLIES 2
dougmcalexander
I have noticed this too Jeff. It has been reported.
wrote in message news:5992408@discussion.autodesk.com...
Is this a bug?
Jeff
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Thank you for your reply Doug,
I would really like to see an effort from Autodesk to clean up many of these “little” issues.
-Jeff
”Boost
