AutoCAD Electrical General Discussion
0 Kudos
Post 1 of 4
Pin list for a new control relay
384 Views, 3 Replies
09-13-2012 02:41 AM
Please help me on the below case.
How we add the pin list values permanently to a newly added component catalog information (new make control relay). When inserting the same component with catalog details previously used on the next sheet the pinlist values are blank.
regards,
Rajesh
76 Kudos
Post 2 of 4
Re: Pin list for a new control relay
09-13-2012 06:34 AM in reply to: psrajesh4u
In the default_cat.mdb file, there are several tables for each of the manufacturer's in teh database. The tables are named "_pinlist_Manufacturer's Name".
Within each table is listed all the parts with pinlists.
Bob Hanrahan
Ace User since 1998
292 Kudos
Post 3 of 4
09-13-2012 06:51 AM in reply to: psrajesh4u
Use the Pin List Database Editor.
1. Select the manufacturer name.
2. Click to add a new record.
3. Enter part number.
4. Enter coil pin (terminal) numbers comma delimited with no space.  (i.e. K1,K2)
5. Enter the contact pins with the proper syntax.  (i.e. 1,A1X,A1Y;1,A4X,A4Y where 1=NO, and A1X,A1Y=contacts)
Hint: Separate multiple contacts with semicolon.
Note: Click Help at lower right of dialog to get the complete list for different types of contacts.
1=NO
2=NC
3=SPDT (a.k.a. Changeover, Form-C)
In the admin class I teach, we cover this topic and we even add pin assignments for 3-phase switch disconnects and circuit breakers.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
0 Kudos
Post 4 of 4
09-13-2012 08:34 PM in reply to: dougmcalexander
Sir,
Thank you for show me the right way.
regards,
Rajesh.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
