AutoCAD Electrical Forum
Patch failure.
3 REPLIES 3
halsteaw
502 Views, 3 Replies
Patch failure.
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoca...
This doesn't seem to fix what it is supposed to. The .PDF CLEARLY says my product is affected...but the patch isn't applying. See output below.
Attn: John Oblad
Hotfix.vbs - by Autodesk 5/6/2014 12:00:00 PM
Hotfix Mapping:
18.1.49.0 => 18.1.75.0
18.1.75.0 => 18.1.75.0
18.1.208.0 => 18.1.250.0
18.1.250.0 => 18.1.250.0
18.2.51.0 => 18.2.75.0
18.2.75.0 => 18.2.75.0
18.2.205.0 => 18.2.250.0
18.2.250.0 => 18.2.250.0
19.0.55.0 => 19.0.75.0
19.0.75.0 => 19.0.75.0
19.0.204.0 => 19.0.250.0
19.0.250.0 => 19.0.250.0
19.1.18.0 => 19.1.75.0
19.1.18.1 => 19.1.75.0
19.1.75.0 => 19.1.75.0
Installed Products: {5783F2D7-A007-0409-0102-0060B0CE6BBA}
The following supported products have been found on your system:
AutoCAD Electrical 2012 - Will not be updated, this version isn't supported: 18.2.107.0
HighestAcdb18Ver = 0.0.0.0
HighestAcdb19Ver = 0.0.0.0
HighestAcdb18Ver_x86x64 = 0.0.0.0
HighestAcdb19Ver_x86x64 = 0.0.0.0
Applying hotfix for shared files:
Final list of updated files:
3 REPLIES 3
mathalekar
in reply to: halsteaw
We are investigating the case in AutoCAD Electrical side. Will keep you updated.
mathalekar
We confirm the issue that you are seeing. Our team is investigating the case now. Apologies for the inconvenience caused and thanks for reporting.
halsteaw
in reply to: mathalekar
I would like to make one comment, if I may.
Many enviroments such as the DoD have disabled VBS scripts for security purposes. It would be better if a security patch were not a VBS script requiring modification to a client's security posture to implement.
An EXE or MSI would be better....
Respectfully,
~Warren H.
”Boost
