Everytime i paste anything (block, line, symbol or wire) it goes way left of my cursor. It seems to be the same distance from my cursor everytime but not positive. Has anyone ever ran into this?
Solved by testsubject. Go to Solution.
Do you have the UCS set to something other than World?
I had that problem with using Swap/Update block shifting everything I changed off the page.
Does the item always move the inserted symbol to the end of a line? You need to Turn Osnaps off.
Just a couple of things right off the top of my head...
That was it i changed my UCS earlier and forgot. Great answer and quick response. Thanks
