IM HAVING PROBLEM
5 WORKER USES THE SAME DATABASE
2 OF THEM
CAN'T FIND SOME ITEM'S WITH THE "PART CATALOGUE WINDOW"
( WHEN SEARCHING WITH "SEARCHING CATALOGUE DB, ITEM FOUND, BUT CAN'T BE SELECTED
ALL OTHER WORKERS USING THE SAME DB WITH NO PROBLEM
I CHECKED ALREADY PROPERTIES SETTING
AND CAN'T FIND THE PROBLEM
ALSO DID A FULL UN-INSTALL AND REINSTALL, BUT THIS HELPED ONLY FOR A WEEK ,AND THEN PROBLEM REPEAT AGAIN
make sure that the support file search paths are set up the same. The search paths are searched in order from the top down. make sure they are the same and also in the same order.
ACADE will search until it finds the first MDB and use that.
Hope this helps
Dennis
