AutoCAD Electrical Forum
Parts Catalog Lookup Table
2 REPLIES 2
KOBI1912
378 Views, 2 Replies
IM HAVING PROBLEM
5 WORKER USES THE SAME DATABASE
2 OF THEM
CAN'T FIND SOME ITEM'S WITH THE "PART CATALOGUE WINDOW"
( WHEN SEARCHING WITH "SEARCHING CATALOGUE DB, ITEM FOUND, BUT CAN'T BE SELECTED
ALL OTHER WORKERS USING THE SAME DB WITH NO PROBLEM
I CHECKED ALREADY PROPERTIES SETTING
AND CAN'T FIND THE PROBLEM
ALSO DID A FULL UN-INSTALL AND REINSTALL, BUT THIS HELPED ONLY FOR A WEEK ,AND THEN PROBLEM REPEAT AGAIN
2 REPLIES 2
acade2012
in reply to: KOBI1912
make sure that the support file search paths are set up the same. The search paths are searched in order from the top down. make sure they are the same and also in the same order.
ACADE will search until it finds the first MDB and use that.
Hope this helps
Dennis
KOBI1912
in reply to: acade2012
THE PROBLEM IS NOT THE ORDER OF The search paths
BECAUSE THE CATALOGUE SEARCH INCDICAT THE PATH OF DATABASE ,AND IT IS CORRECT
ALSO NOTICE , ALL ITEM NEEDED ,DO EXIST IN THE MDB File
But can't be selected!
Best Regards
Kobi Gerbi
I.L.S. electromechanical supplies l.t.d
*Tel-ILS: +972-9-8851366
*Tel-Direct: +972-9-8851366
* Fax: +972-9-8851270
* Mobile: +972-52-6262947
* kobi@kahane.co.il:mailto:kobi>:mailto:kobi>
”Boost
