AutoCAD Electrical Forum
Part/ Catalog Number Favorites?
4 REPLIES 4
awallace
340 Views, 4 Replies
Is there a way to "favorite" a part or something so I quickly find what I usually use when starting a new project?
4 REPLIES 4
drathak
in reply to: awallace
Quick, simple and built right in?  No.
You can create a stripped down catalog database and make the full catalog your secondary, but you have to maintain it.  (ie add any new favorites to the stripped down copy.)
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
awallace
in reply to: drathak
Autodesk should really consider adding such a feature. It would be nice, especially when it comes to picking out that terminal block...
drathak
I suppose I should mention that we are still on 2013.  The new catalog browser in 2015 may have something like that.
Hope to get my test box soon...
Joe Weaver
dougmcalexander
There are multiple ways. You can use the method of main and secondary, like the previous post suggested. You can set the _LISTBOX_DEF table of the catalg database to cause Lookup to jump straight to a favorite manufacturer, favorite style, series, voltage, etc.
You can also load the MISC_CAT table with your absolute favorites and set your project to display only parts from this table.
You can use the WDBLKNAM field method to return only certain part numbers, based upon the block name of the symbol you are editing. Autodesk has already used this method to narrow down the list for pilot lights, so you only see red pilot lights if you are editing a red pilot light symbol. You can look at the pilot lights in the catalog database for an example.
You can create a project-specific list and get part numbers only from there.
The Catalog Browser in version 2015 allows you to select the part number first and map a symbol that automatically pops up when you select that part number.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
