AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
PARENT Symbol Defaulting to CHILD ...
2 REPLIES 2
387 Views, 2 Replies
Using ACADE 2014 (new user).  I have  a symbol that I created named HTD1_ODT (it's an on-delay timer relay).  It is saved in my custom symbols folder.  When I use it, I get the CHILD block dialog instead of the PARENT dialog on insertion.  Not sure why this is happening since I believe it is named as a PARENT (4th char. is a 1).  Unfortunately, I really don't remember which block I used as a starting point for the new symbol (maybe it was a CHILD).  Are there specific attributes (or other metadata) that a block has when it's a CHILD that could be causing ACADE to treat this as a CHILD and not a PARENT?  Worst case, I can just re-create the symbol using a PARENT base, but if there's an easy way to fix what I have, I'd like to know how & why this is happening.  Appreciate any help.
2 REPLIES 2
Icemanau
Make sure your block is using TAG1 instead of TAG2.
TAG2 brings up the child dialog box while TAG1 brings up the Parent dialog box.
Also make sure that you have added the CAT, MFG, FAMILY attributes as well.
If that fails, post the block here so we can take a look at it.
Regards Brad
Brad Coleman, Electrical Draftsman
in reply to: Icemanau
Thank you very much.  Switched to TAG1 and added the other attributes and it's now working perfectly.  This is all starting to make sense! (woops, probably shouldn't have said that Smiley Surprised!).  Thanks again.
”Boost
