AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
parent child
1 REPLY 1
158 Views, 1 Reply
parent child
See attached drawing. Parent component has 3 NO contacts of which 33,34 is not used.
Nevertheless, When I edit the 3th child and choose the List button 33,34 does not appear in NO Pairs. Why?
AE 2008 SP1
1 REPLY 1
There does seem to be some issue in AcadE here although I am not sure what
it is yet. If I delete the contact and insert a new one it automatically
uses the free set of pins. Or, if I use the Toggle NO-NC function and switch
it first to NC (it gets NC pins) then switch back to NO it gets the NO pins
correctly. I will look more closely at this and log any issues if necessary
but you can use either one of those as a workaround for now.
Pat Murnen
wrote in message news:5822877@discussion.autodesk.com...
not used.
AE 2008 SP1
”Boost
