A parent/child relation is established by simply having the TAG2 attribute
value on a child schematic symbol have the same value as what is present on
a TAG1 attribute value on a parent schematic symbol. You don't have to use
AcadE to do this. You can use any AutoCAD attribute editor cmd to set this
relationship.
If you are running in the "IEC tagging mode", then you may need to have the
symbol's INST and LOC attribute values match as well.
Nate.
wrote in message news:5380395@discussion.autodesk.com...
Is it possible to establish a parent child relationship automatically
without using the Insert/Edit Child Components dialog box?
What i'm trying to do is create an entire drawing with parent components and
then from this drawing create an other drawing containing only child
components. I would like to have this child only drawing created from a
parent list.
Is this possible?
