Hi all,
I wish to create PLC module with the PLC database editor.
I want use the Cube67+ family from Murrelektronik. Those are IP67 field modules with M12 or M8 connections
And almost i want use is multifunction DIO16 8xM12 modules. Each PLC channels can be input or output.
According to gsd file, the pins 2 and 4 of each M12 connector can be either Input or Output or Diagnosis Input according to parametrization in the PLC software.
In the Step7 HwConfig (as i will programm a S7-300 PLC) the pin 2 and 4 of each M12 channel has both the input address and the output address, only the parametrization seems let the pin as an Input or Output. (see image appendix)
I would like the adress to appear all (like you see in HwConfig), in the right order, and without doing addressing by hand or choose at each input/output which value it should take when inserting it.
Is it possible with the PLC database editor ? How ?
Or should i build it myself like the subject "Symbol Auto Fill Attribute"?
Thanks in advance for help you may suggest !
That would be a nice to have, but one way around this is to create multiple modules in a few combinations.
