It looks like the library symbols that are used to build the PLC modules do
not have the XREF attribute on them. If you want one you would need to add
it to the set of top symbols. These are the symbols that carry the
attributes that you only want one of on the entire module, such as MFG, CAT,
INST, LOC, etc. You would add the XREF attribute definition to these
symbols. The naming convention for these is HP*L.dwg for horizontal and
VP*L.dwg for vertical. Only the ones that end in "L" are the ones that are
used at the top of the symbol. When you open the drawing if it doesn't carry
the attributes I mentioned then don't add the XREF to it. These library
symbols are in your schematic library folder.
Hope this helps,
Pat Murnen
wrote in message news:5770126@discussion.autodesk.com...
Hi
We are using ACE2008. I tried to insert a Siemens PLC card 32DI 24 V The
part number in the table is as follows "6ES7 321-1BL00-0AA0" . I check for
hidden xref attributes but found none.
