I am trying to setup a parametric build for a unusual module. I am forcing the addressing to be in a particular format using the slot number rather than having a prompt for the address. My problem is that after I insert this module and want to change the slot number with “edit component and change the first address field it only changes the first sequence. This is the error it gives me; “Not all address values were resequenced. Check and manually edit as required.”
Can this be fixed?
Here is an example of the addressing I am forcing;
XRn1.1
XRn1.2
XRn1.3
XRn1.4
XRn1.5
XRn2.1
XRn2.2
XRn2.3
XRn2.4
XRn2.5
XRn3.1
XRn3.2
XRn3.3
XRn3.4
XRn3.5
XRn3.6
XRn3.7
XRn3.8
Where n is the slot or module number
