AutoCAD Electrical General Discussion
Dan.M
Message 1 of 9 (479 Views)
Panel layout
479 Views, 8 Replies
01-09-2013 11:53 AM
Hello
I woudl like to do a simple thing...Put some enclosures on my drawing and blocks from Icon Menu inside those enclosures. When ever I put the blocks(relays,breakers, plc...) I want them to take the Location or the Tag of the enclosure.
Now when I build a report From to I get where my Relay is and from where the wire starts and where it ends.
Is it possible?
Dan
oveimariemamn
Message 2 of 9 (453 Views)
Re: Panel layout
01-10-2013 03:47 AM in reply to: Dan.M
Yes sure,with the correct commands ,like use wire command and not line command.
Dan.M
Message 3 of 9 (445 Views)
Re: Panel layout
01-10-2013 05:04 AM in reply to: oveimariemamn
Yes I use wire command. I did not meant to get from /to report by using lines...
But Electrical is not allocating automaticly Tag of the enclosure to the block inside of it.
Dan
Nata_ly
Message 4 of 9 (436 Views)
Re: Panel layout
01-10-2013 05:37 AM in reply to: Dan.M
Sorry, but could you please answer a question to make me sure I understand you correctly?
Do you want to make From/To report from layout?
As I know From/To report is a scheme report, not layout. So you could make scheme firstly. And if you want to see wire destination on layout you can use Wire annotation command.
Have I garbled smth?
Dan.M
Message 5 of 9 (427 Views)
Re: Panel layout
01-10-2013 06:15 AM in reply to: Nata_ly
Lets say everything is in the schematic zone. I have Panels just rectangles with a number(see drawing)
Whenever I place something(relay) inside this block I want it to know it is there and then when building report from/to
the relay knows in which BOX he is in and the wire goes form that Relay K1 BOX 2 to something else(terminal) BOX3 in the same drawing...
I hope it is clear
Dan
Nata_ly
Message 6 of 9 (396 Views)
Re: Panel layout
01-11-2013 06:15 AM in reply to: Dan.M
I understand now. But maybe all I could advise - use command AECOPYLOC after inserting all components to make location code editing faster and comand AEEDITWIRESEQUENCE to edit wires destination if it's so important.
Maybe only lisp can help to make it automaticaly. :smileysad:
Nata_ly
Message 7 of 9 (367 Views)
Re: Panel layout
01-15-2013 03:18 AM in reply to: Dan.M
Please, read the article "Location box" in Help! This command could help you.
"Schematic tab Insert Components panel Location Box drop-down Location Box
A location box is drawn around devices to designate that they are physically in a different location/installation than the other devices in the drawing. The box is a closed polyline and can be a rectangle or some other orthogonal shape.
The Location and installation codes for the parent components within the location box update to match the location box. You can assign a description to the box. The program prompts for updates to related components and panel footprints."
Dan.M
Message 8 of 9 (359 Views)
Re: Panel layout
01-15-2013 04:26 AM in reply to: Nata_ly
It sounds like a solution. I will check
Thank you for the help
dan
Dan.M
Message 9 of 9 (333 Views)
Re: Panel layout
01-16-2013 09:54 AM in reply to: Nata_ly
Thank you,
Problem solved
Dan
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
