Chad,
The path for the footprint lookup file is also controlled in the WD.ENV
file. By default, this file is located in:
C:\Documents and Settings\{username}\Application Data\Autodesk\AutoCAD
Electrical 2007\R17.0\enu\Support\AeData\Catalogs
But if you have shared this location on the network, you can point ACE to
this new location by changing the following line in the WD.ENV file:
WD_CAT,%WD_DIR%/catalogs/,AE catalog file path
So this line might be something like:
WD_CAT,n:/Catalogs/,AE catalog file path
Steve
wrote in message news:4878044@discussion.autodesk.com...
Martin,
I don't ever remember having to change the search path before.
I think all I need to do is get the program to look at the correct footprint
lookup file - but how is the question.
Chad
