AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Panel Footprint Scaling
4 REPLIES 4
STEVENAR
1489 Views, 4 Replies
When I insert footprints of panel components from the IEC libraries into a panel at a 1 to 1 scale. The scaling of the components it not right. The components are too small. Can someone please advise on how to correct this.
Thanks.
4 REPLIES 4
testsubject
in reply to: STEVENAR
My guess is that you are using a drawing that is set up for metric and all the footprints are set up for standard.
When you insert a footprint, you are given the ability to change the insertion scale of the footprint at the bottom of the Panel Icon Menu. Set it for 25.4 and al lthe footprints should scale just fine.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Like Bob said, it sounds like you are using a metric environment. You can click on the Configuration icon on the Panel tab and preset the scale factor for panel layout symbols so you don't have to enter the scale each time you insert a symbol.  See attached screen capture.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
STEVENAR
in reply to: dougmcalexander
That's my problem solved.
Thanks guy's.
Hi Doug,
I have the same problem but the other way round. My blocks are in mm, and I have enormous blocks when I insert them in my Imperial (inches) working frame.
I also noticed that after inserting the block, the drawing scale turns from "inches' to "Unitless"
I have ACADE 2010.
Regards
”Boost
