Marty, what you have is a configurable product line. AcadE has just what you need. I have used it since 1997 when it was called Toolbox/WD, and I worked at a company doing the exact same thing you seek.
You need to make use of the Location codes. Possibly even the Installation codes. You can assign your option circuits to a particular location code. For example, I have a machine that might include up to 14 motor drives, 32 heat zones, pressure monitoring, level control, etc., but it is up to the customer exactly which features they want. The schematic includes all options, but I designate each option using a location code. For exampe I have a location code of DRV1, DRV2, DRV3, etc. for each motor drive circuit, PRS1, PRS2, PRS3, etc. for pressure monitoring circuits and so forth and so on. When I create my parts list or BOM, I filter to the location code I need and place this report on its own unique drawing with its own document number. I do the same for the wire list. I do this for all possible options. The panel layout shows all possible options, but again the wire list and parts list control what actually gets installed.
I recently completed a project for a customer of mine that was over 200 pages, doing exactly what I described above. I started out designing for a German company so I do DIN/IEC style drawings, where each page has its own Installation and Location code. AcadE allows you to declare the INST and LOC code on a per sheet basis so all components on the page are automatically assigned to this INST and LOC. For anything on the page that is from a different INST and/or LOC I insert an intelligent location box using AcadE and this box designates all components within it as being from a different INST and/or LOC than the rest of the components on the page.
AcadE is well-equipped to handle your situation. I travel the world teaching custom and advanced classes on AutoCAD Electrical implementation. You can reach me at ECADConsultant@aol.com.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
