AutoCAD Electrical General Discussion
Active Member
Gagg
Message 11 of 16 (312 Views)
Re: One Line Diagram Help!
09-28-2012 11:42 AM in reply to: Gagg
Do I have to insert all the "required" tags?  If there are any errors errors found in the symbol, will this cause them not to work?
testsubject
Message 12 of 16 (310 Views)
09-28-2012 11:47 AM in reply to: Gagg
A quick look shows that you are missing all the info that is needed in the symbol to make it intelligent:
I recommend using Symbol Builder which will provide you with all the attributes that need to be on a symbol to make it intelligent.
You also need to change the way you name symbols.
ACE uses the following format:
1st Char - H or V for horizontal or vertical insertion.
2 and 3 char - the family code for th esymbol; i.e., CR for relays, MO for motors, SS for selector switches. This is how ACE knows which table to look in in the database for part information.
4 char - 1 for the Parent Symbol and 2 for the Child Symbol
5 char - 1 is a NO contact, 2 is a NC Contact. Used mostly with relay children symbols and switches.
6 char and up - these can be whatever you want to make the symbol distinctive.
Here is a wiki that goes into it in more detail
http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2011/Help/User's_Guide/104SymbolLibraries/1085Li...
Hope this helps.
Bob Hanrahan
Ace User since 1998
Active Member
Gagg
Message 13 of 16 (302 Views)
09-28-2012 12:43 PM in reply to: testsubject
Thank you for the quick reply. I did use symbol builder when I created them. I changed name and file save location though, should I keep ace's default naming and save location. It sounds like that would help. I am just trying to create a basic line diagram, my blocks do not need to be intelligent(except for wire connectin points). Should I just attach them as xrefs and connect the wires to a spot on the box, not an actual "terminal". I have a feeling I am making this much more complicated than it needs to be. Thank you again
Active Member
Gagg
Message 14 of 16 (296 Views)
09-28-2012 01:26 PM in reply to: testsubject
Ok it appears that renaming the block accouding to the way Bob explained has fixed the problem. THANK YOU!!
testsubject
Message 15 of 16 (293 Views)
09-28-2012 02:05 PM in reply to: Gagg
Not a problem. I like to help.
Bob Hanrahan
Ace User since 1998
Active Member
Gagg
Message 16 of 16 (288 Views)
09-28-2012 02:29 PM in reply to: testsubject
I thoight it fixed the issue but it didn't. Im getting closer but not 100%. Thanks again tho
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
