AutoCAD Electrical General Discussion
Member
DanG
Message 1 of 4 (207 Views)
Old Block Attributes
207 Views, 3 Replies
11-03-2003 05:52 AM
Older blocks (from before AE) do not prompt for data when inserted. I'm used to seeing the prompts on the command line. Is there a switch that contols this?
DanG
ASM
*Autodesk, Inc\
Message 2 of 4 (207 Views)
Re: Old Block Attributes
11-03-2003 06:11 AM in reply to: DanG
Dan
    That sounds like you are using
the Vanilla AutoCAD insert.  You want to try and use the INSERT COMPONENT
and INSERT FOOTPRINT functions from the Electrical package as much as
possible.  They have additional functionality built in which the VANILLA
AutoCAD INSERT does not and therefore using it could create more work for
yourself.  There is a variable for prompting for attribute values,
ATTREQ  set this to 1.
Good Luck!
Sincerely,
Jared Bunch
Technical Support Specialist
Autodesk, Inc
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Older
DanG
ASM
Member
DanG
Message 3 of 4 (207 Views)
11-03-2003 10:25 PM in reply to: DanG
Thanks!
DanG
ASM
Active Member
KABrown5303
Message 4 of 4 (207 Views)
04-18-2006 11:07 AM in reply to: DanG
I am having an issue with ATTREQ resting to 0. I'm working in a project with approx. 30 different drawings. It seems after I switch from drawing to drawing a few times, it resets. Is there a fix for this?
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
