Hi Chad,
You should get a proxy message any time AutoCAD Electrical encounters a
special object from AutoCAD Mechanical. The message is more of a question
asking you how you would like the proxy to be displayed than it is a warning
or error.
If you would like to suppress this question, you can change the
"Proxynotice" variable to "0". Just type "proxynotice" at the command line
and set it to "0".
Give that a try and see if it gives you the desired results.
Scott
wrote in message news:4864617@discussion.autodesk.com...
Scott,
Thanks for the info, but even with the "check for enablers turned off" I
still get the errors about proxy graphics.
Any other ideas?
Chad
