For some strange reason, it seems that my o-snap settings are not being retained between operations. Is this a known bug, or am I doing something wrong? Thanks.
Solved by rhesusminus. Go to Solution.
I look at the F1 on that command, doesn't appear like it's what I am talking about, but I'll give it a try, maybe it's a work-around type thing?
edit: just tried it, does not work. For some reason, the "intersection" o-snap keeps turning off by itself after I add a new component.
You are not crazy
I just checked here, and the INTersection snap is the only osnap being turned off after a symbol insert.
Seems like a bug.
I guess so... I've already reported this in the beta-group for the next release though.
Just ran into this myself. As a workaround using "Apparent Intersection" seems to work most of the time.
At least it has so far...
