AutoCAD Electrical General Discussion
Active Contributor
DBrohm
Message 1 of 32 (1,921 Views)
Next Sheet Number
1921 Views, 31 Replies
02-11-2009 08:57 AM
Good Morning;
The majority of my customers require their title blocks show the current sheet number, for which I utilize the %S variable. Additionally, they want the maximum number of sheets indicated, which is a standard “title block update” function, as we all know. So far easily done.
Where my challenge comes is the odd customer prefers the next sheet number to be displayed in the title block as opposed to the maximum number of sheets. Up to this point in time we have been editing that information manually. Is there a means by which to automatically “calculate” that value based upon the current sheet number or to read the next sheet number from the project database? If there is I am unable to determine what that method would be.
Any suggestions, help would be appreciated.
Doug
dougmcalexander
Message 2 of 32 (1,921 Views)
Re: Next Sheet Number
02-11-2009 01:11 PM in reply to: DBrohm
There is a way to do this. It requires a lisp file be installed into the AcadE main program folder under program files and a special text string to be entered at the end of the WD_TB mapping attribute in your border template. You will need attributes called NEXTSHT and PREVSHT located as desired on the drawing border. I have attached the lisp file. Change the .zip extension to .lsp. Put this under Program Files\Autodesk\Acade 2008 or 2009 or whatever you are running.
Below is the text string you need to add to the end of the WD_TB attribute's value:
;PREVSHT = (if (setq x (findfile "tbnp.lsp" ))(progn(load x)(c:smileytongue:revsheet)) " ");NEXTSHT = (if (setq x (findfile "tbnp.lsp" ))(progn(load x)(c:nextsheet)) " ")
Note: When I create borders for European customers, I usually place the PREVSHT and NEXTSHT attributes inside arrows so language is not a barrier. I have an arrow pointing left on the left side of the page near the bottom to indicate previous sheet and one facing right on the right side of the page indicating next sheet.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
Active Contributor
DBrohm
Message 3 of 32 (1,921 Views)
02-12-2009 05:16 AM in reply to: DBrohm
First of all thank you very much for your help, the lsp file and attributes work like a charm, this will save not only myself, but my entire group of hardware designers an immense amount of time as we move forward. It has been a large number of years since I was involved in any amount of lsp programming, and even then it was minimal at best. For me to have figured that out on my own would have taken a great deal of time that I do not have. I do not wish to impose on your generosity; however, I do have one question further. What would I need to alter if I needed to have a specific character(s) shown in the “nextsht” attribute as opposed to a black on the final page of a project?
Again many thanks for your help.
Distinguished Contributor
mako68
Message 4 of 32 (1,832 Views)
12-16-2010 12:30 AM in reply to: DBrohm
I couldn't get this "previous/nextsheet" lisp work with ACADE2011. Is it so that WD_TB allows max is 256 characters? In that case there is not much space left for other attributes...
Regards
Mako
Active Contributor
DBrohm
Message 5 of 32 (1,711 Views)
01-07-2011 06:01 PM in reply to: mako68
You might want to consider using the “wdt” file method of title block updating that is what we use and thus far no issues that I have found.
dougmcalexander
Message 6 of 32 (1,697 Views)
01-08-2011 07:41 AM in reply to: mako68
It works..  Edit WD_TB with Propetties, not Attribute Editor.  Attribute Editor is limited to 256 characters but Properties is not.
Doug McAlexander
Member
chintan0910
Message 7 of 32 (1,456 Views)
04-05-2011 11:19 PM in reply to: DBrohm
Hello Dear,
My client required Next Sheet number in the title block.
I had past tbnp.lsp file on specific location. & I had also update *.wdt file with your specified text string for NEXT SHEET. But while I am using Project-Title block setup-WD_TB att. Method- I can not get NEXTSHT in Drawing properties. So please guide me what can I do ?
Please send me the step for the process.
Member
chintan0910
Message 8 of 32 (1,449 Views)
04-06-2011 02:51 AM in reply to: DBrohm
Hello Dear,
Valued Contributor
druida78
Message 9 of 32 (1,423 Views)
04-07-2011 09:18 AM in reply to: DBrohm
Hi.
What is the way to create a WD_TB mapping attribute?
Thanks.
Ernesto Fraga
I title block update without it and it works but I would like to improve.
Ernesto Fraga
Montevideo - Uruguay
Arq. Ernesto Fraga
Employee
KevinLi-Autodesk
Message 10 of 32 (1,398 Views)
04-07-2011 11:50 PM in reply to: druida78
Does the way defined in the help document help you to create it ? I capture the screenshot and attach it.
Kevin Li
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
