AutoCAD Electrical General Discussion
*krollenhagen
Message 1 of 6 (171 Views)
Next / Prev Project Drawing Buttons
171 Views, 5 Replies
12-04-2003 11:45 PM
What changes do I have to make to the buttons that go to the previous and
next project drawings so that before changing drawings, it will zoom
extents?
I have tried a few different things in the code for the button but can't
seem to get it to work. I do not know lisp programming and I think that is
what is used for the button.
Here is the code on the button currently for the next project drawing
button:
^C^C^P(if(not wd_load)(if(setq x(findfile "wd_load.lsp"))(load
x)))(wd_load);(c:wd_proj_dnext)
If you have any suggestion, please let me know.
Thank you,
Keith Rollenhagen
Thierica Automation Group
*krollenhagen
Message 2 of 6 (171 Views)
Re: Next / Prev Project Drawing Buttons
12-05-2003 12:09 AM in reply to: *krollenhagen
I finally got it to work. I put the code for the zoom extents button before
the code for the next drawing button so that it looked like this now:
'_zoom _e ^C^C^P(if(not wd_load)(if(setq x(findfile "wd_load.lsp"))(load
Now, if I have made changes to the drawing, it will zoom extents before
saving the drawing to disk.
"krollenhagen" wrote in message
news:41C59D9203176EC7085ED6F4B7FF23AA@in.WebX.maYIadrTaRb...
> extents?
is
> button:
> Thank you,
> Keith Rollenhagen
*Autodesk, Inc\
Message 3 of 6 (171 Views)
12-05-2003 12:13 AM in reply to: *krollenhagen
Keith
This appears to work. Give it a try:
x)))(wd_load);_zoom e (c:wd_proj_dprev)
{I added the _zoom e }
Sincerely,
Jared Bunch
Technical Support Specialist
Autodesk, Inc
> extents?
is
> button:
> Thank you,
> Keith Rollenhagen
Jesse Reynolds
Message 4 of 6 (171 Views)
12-21-2005 07:51 AM in reply to: *krollenhagen
Jared,
Where this file located?
Also, Instead of clicking the Next/Prev is it possible to turn it into a keyboard command?
- Jesse
Distinguished Contributor
chubby-1
Message 5 of 6 (171 Views)
12-21-2005 08:35 AM in reply to: *krollenhagen
The buttons they are talking about have macro's assigned to them. If you are wanting to view or modify the button assignments....do the following:
1) on the main menu....select "view"
2) then select "toolbars"
3) then select the "Properties" tab
4) select the toolbar button you wish to modify. in the case of this post they are discussing the next and previous drawing arrows in ACE.
Hope this helps
Marty
Jesse Reynolds
Message 6 of 6 (171 Views)
12-21-2005 09:19 AM in reply to: *krollenhagen
Marty,
Thanks it works like a charm.
Jesse
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
