AutoCAD Electrical General Discussion
Valued Contributor
jtwalker1
Message 1 of 6 (2,094 Views)
New to electrical, only have Allen Bradley parts
2094 Views, 5 Replies
04-18-2012 10:30 AM
Installed Electrical as part of Inventor Suite, but the only Manufacturer parts that are listed are from AB, how do we add additional parts from other manufacturers?
Thanks,   I am sure I will smack myself in the head once someone tells me cause it is probably simple
testsubject
Message 2 of 6 (2,092 Views)
Re: New to electrical, only have Allen Bradley parts
04-18-2012 10:48 AM in reply to: jtwalker1
Don't hit yourself too hard  ;-)
Re-run the installation of the software and when asked for manufacturers', select all the ones that you want.
Bob Hanrahan
Ace User since 1998
Valued Contributor
jtwalker1
Message 3 of 6 (2,090 Views)
04-18-2012 10:54 AM in reply to: testsubject
It does not give me the option, when inventor installs it installs everything with no real interaction or questions.
Member
brent.duncan
Message 4 of 6 (2,088 Views)
04-18-2012 10:57 AM in reply to: jtwalker1
I'm in the process of doing the below steps right now.  I also didn't get the select manufactueres during installation.  I don't know if downloading versuses using a dvd makes the difference or not.
http://docs.autodesk.com/ACAD_E/2013/ENU/index.html?url=filesAcadE_WhatsNew/GUID-61E726C5-69C4-417A-...
During installation, you specified which manufacturer content to install. You can install additional manufacturer content later.
  1. Close all instances of AutoCAD Electrical.
  2. From the Windows Control Panel select Add or Remove Programs.
  3. From the Add or Remove Programs dialog box, select the latest version of AutoCAD Electrical and click the Change/Remove button.
  4. On the AutoCAD Electrical Installation Wizard, click Add or Remove Features.
  5. On the Manufacturer Content Selection page, select all the manufacturers you wish to install. Click Next.
  6. On the Select Symbol Libraries page, click Next.
  7. Click Update.
testsubject
Message 5 of 6 (2,082 Views)
04-18-2012 11:17 AM in reply to: brent.duncan
That is another way to do it.
Bob Hanrahan
Ace User since 1998
Valued Contributor
jtwalker1
Message 6 of 6 (2,080 Views)
04-18-2012 11:18 AM in reply to: brent.duncan
That took care of it.
Thank you for your help
James
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
