Installed Electrical as part of Inventor Suite, but the only Manufacturer parts that are listed are from AB, how do we add additional parts from other manufacturers?
Thanks, I am sure I will smack myself in the head once someone tells me cause it is probably simple
Don't hit yourself too hard 😉
Re-run the installation of the software and when asked for manufacturers', select all the ones that you want.
It does not give me the option, when inventor installs it installs everything with no real interaction or questions.
I'm in the process of doing the below steps right now. I also didn't get the select manufactueres during installation. I don't know if downloading versuses using a dvd makes the difference or not.
During installation, you specified which manufacturer content to install. You can install additional manufacturer content later.
That is another way to do it.
