AutoCAD Electrical General Discussion
mikegoutier
Message 1 of 11 (433 Views)
new terminals for terminal block layout
433 Views, 10 Replies
01-16-2013 12:05 PM
I am trying to use a new phoenix terminal that is not yet in my 2010 database (electrical). I got the .dwg form the phoenix website and I want to add it to my database to use it all the time. How can I accomplish this?
Terminals are grouped by the TB they are associated with. TSE (Terminal Strip Editor) has the built in intelligence to check the size of the terminal and place the next one in the terminal block list right next to the previous one.
By default, the TSE will build the terminal strip so that it will go on a Dinrail that is mountaed vertically. Therefore, all template drawings have to have the terminals drawn horizontal, not vertical. From within TSE, you can tell it what the orientation is.
What you need to do is open your symbol drawing, rotate it (with 0,0 as the rotation point) so that the "Bottom" of the terminal is on the left side.
dougmcalexander
Message 2 of 11 (421 Views)
Re: new terminals for terminal block layout
01-16-2013 05:01 PM in reply to: mikegoutier
Use the symbol Builder to add the appropriate attributes for a terminal footprint.  Use AutoCAD’s Wipeout command to outline the portion of the terminal that should hide DIN rail behind it.  Enter the part number into the CATALOG database for part number assignment and make an entry in the footprint lookup database to direct the software to use your downloaded footprint when that part number is assigned.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
mikegoutier
Message 3 of 11 (406 Views)
01-17-2013 07:07 AM in reply to: dougmcalexander
Everything seems to be working correct now except I cant get the terminal blocks to go next to each other. They are always in a line.. any ideas?
Nata_ly
Message 4 of 11 (403 Views)
01-17-2013 07:11 AM in reply to: mikegoutier
Rotate? I mean a template of the terminal.
mikegoutier
Message 5 of 11 (399 Views)
01-17-2013 07:15 AM in reply to: mikegoutier
A little more info...
In symbol builder I am building a "panel terminal"
Type is generic
I put in the MFG and CAT
Then I go into wire connection go to others and select 2 level (because its a 2 level terminal)
and than put a wire connection on one of the terminals
than closed and saved the symbol
I then use the command AEFOOTPRINTDB and add the location i saved the symbol in.
I than go to editor and select my TB (just 3) and use the layout preview and there all in a row...
testsubject
Message 6 of 11 (395 Views)
01-17-2013 07:24 AM in reply to: mikegoutier
It sounds like the terminal template is vertical instead of horizontal. As Nata_ly suggested, rotate the template and it should look okay in TSE. ACE expects the terminal blocks to all be horizontal. You can change the orientaion during the insert from within TSE. Be sure to purge the drawing first to get rid of any existing blocks that are not referenced in the drawing.
Bob Hanrahan
Ace User since 1998
mikegoutier
Message 7 of 11 (385 Views)
01-17-2013 08:10 AM in reply to: testsubject
But How can I change how the proceding terminals are inserted, IE ontop, to the left, to the right.....
In other words I create 1 terminal in SE
But my terminal block layout has 30 terminals how does it know where to put the new ones in relation to the original.
testsubject
Message 8 of 11 (379 Views)
01-17-2013 08:37 AM in reply to: mikegoutier
Bob Hanrahan
Ace User since 1998
mikegoutier
Message 9 of 11 (375 Views)
01-17-2013 09:16 AM in reply to: testsubject
That explains everything, a nice ahhhhhhhhhhh moment. Thank you for your time.
mikegoutier
Message 10 of 11 (359 Views)
01-17-2013 12:19 PM in reply to: mikegoutier
one more quick one. So If i wanted to perminatly change somehting on the terminal block like the position of text what is the easiest way to do this?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
