I represent FMC Technologies SA in France, as we migrate the project manager autocad license to another server.
We want to migrate all customers FMC (FMC position) version 2013.
This would require me: The license file
The latest official version of the license manager lmgr
Prerequisites hardware / software server.
Can you provide me ?
Thanks in advance,
Karim OUSALEM.
Hi Karim,
You actually need need to go to the License Activation Page to Get your License file.
(or get your re-seller to get it for you)
Here are the steps From the US Site.
After collecting the appropriate server information, you are ready to request a license from Autodesk.
5. Select your Network server type and provide the appropriate server information, which you collected in the above task, Collect License Server Info. Click Next when you are ready to proceed. |
6. Your license file is then issued and will be emailed to the address associated with your Autodesk ID as a “.lic” file attachment.
Note: Your license file will also appear as text in the body of the email, which you can copy and paste to a text editor and save according to the instructions below.
After saving your license file, it is important to confirm that it contains the correct information. Your license file will only work on the machine that has the same Physical address. You can modify the Host Name in your License file but not the Physical address.
To confirm the accuracy of your license file:
3. Verify that the Physical address matches your server’s. If it does not match, you will need to request a new license file with the correct information.
Learn how to find your Host Name and Physical Address.
When you have verified that your license file is correct, you can close it and move onto the last step of Configuring your Server.
As for the other two:
AutoDesk NLM (flexnet) can be downloaded from any Product's service pack page.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16273699&linkID=9240738
(This one is from the AutoCAD Electrical Page, It is version 11.11)
for the Server requirements:
All of the Computers that will obtain licenses from the Server should be able to see the server.
This server shouldn't be a domain controller.
I hope this helps,
James Alger
