AutoCAD Electrical Forum
New Right-Click menus ... Change or Customize?
3 REPLIES 3
JCard
786 Views, 3 Replies
have made the move from ACADE 2012 to ACADE 2014... The new right-click menus are a great graphic effect, and they work, but is there an option to disable these and just revert back to a more standard right-click menus?  Just not seeing the advantage...older menus seem more efficient.
Thanks for any information.
JCard
Electrical Designer
Logical Systems, LLC
3 REPLIES 3
pendean
in reply to: JCard
Edit the CUI as you see fit.
RobinShou-Autodesk
in reply to: JCard
The new right-click menus are Marking Menu in the ACE2014. Please refer to the help document about this new feature.
The main Advantage for Marking Menu is the Gesture, please have a try and see if it is good than the standard context menu.
If you don't like it, please change the sysvar AEMM to 0 to change to the standard context menu.
Robin Shou
Quality Assurance
Autodesk AutoCAD Electrical
JCard
in reply to: RobinShou-Autodesk
Thank you.  At least I have the option to try it and if I don't think it works well for me, at least this way I don't have to put much work into customizing the CUI editing.  I thought there might have been a sysvar or something similar to make the switch.
Thank you again....Great product....
JCard
Electrical Designer
”Boost
