AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Network Pinlist
6 REPLIES 6
dmray
366 Views, 6 Replies
Network Pinlist
Hey there fellow AutoCADers.  I am not using a network install of Electrical, but I have located the default_cat.mdb in a network folder.  My problem?  PINLISTS.  It points to the original install location (work station).  Is there a way, besides reinstalling the software to a network install, that I can force the PINLIST file to look in another location for catalog information?
IN summary:  Default_cat.mdb moved to network folder.  PINLIST database refers to default_cat located locally.  Iw ant to have it read the network one.
Doug
6 REPLIES 6
dougmcalexander
in reply to: dmray
Go to www.ecadconsultant.com and click on the Tips/Tricks page.  Look in the index for a topic called Sharing AutoCAD® Electrical across a network.  What you are trying to do is exactly how I work.  I have a local installation but networked data.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
dmray
in reply to: dougmcalexander
Thats how i have it setup now, but the PINLISTs still referance the catalog on the local drive.  I worked around it by copying the network MDB to the local, but thats not very effieicnt....
Doug
dougmcalexander
in reply to: dmray
Did you rename the local AeData folder like my directions explained?  Did you add the new location for AeData to the top of the Support File Search Path under AutoCAD options?  I'm operating that way now with my laptop.  When I travel I rename my local AeData from AeData_ to AeData so it functions again.  When I get back to the office, I rename the local AeData to AeData_ so the software is forced to use the path listed in AutoCAD options.
Doug McAlexander
dmray
I access the default_cat from the network drive for all my cataloged parts.  (I verified by adding dummy parts ot make sure it works).  I even modified the wd.env file to point to that folder, as that was causing a different issue (I had a different thread on here, which you helped me resolve).  The wd.env file points to the network folder where the default_cat.mdb resides, but the pinlist points to the original/local default_cat.mdb.
Names haven't been changed.  Didnt see the need for that, and the file path IS the top one...
dougmcalexander
in reply to: dmray
If you follow my directions exactly it will work, and everyone will share the same wd.env file.  There is actually no need to modify the wd.env file if you use my method.
Doug McAlexander
CAD-ICE
Hi there,
I know this an old thread but I´m having issues with the pinlist data not being updated when I look up in the secondary database (see attached png)
Anyone else having these issues ? (ACADE2016 64 bit machine)
Regards, Gary
”Boost
