AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Network License Manager
4 REPLIES 4
TomTom111
429 Views, 4 Replies
I recently did a test run with network license manager with a valid license key. All went well, and I was wondering if I need to free up the product key and serial number used to do the test run.
Help is appreciated.
         Thomas
4 REPLIES 4
TravisNave
in reply to: TomTom111
Nah, you shouldn't need it.  If you are going to have a newer license manager and/or file, you can just configure it as needed.  The license manager itself handles the licensing, so there is nothing to free up if you no longer use it.  Hope that makes sense.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
TomTom111
It indeed does make sense. Thank you Travis. I will let you know if all goes well. I am doing the installs this week.
TravisNave
Just post in the Licensing forum if you run into anything.  I'll most likely see it in there.
Autodesk Forums:
TomTom111
Completed the network installs without a hitch. Worked great. Thanks again.
”Boost
