<dougmcalexander> wrote in messageNate
href="news:6138199@discussion.autodesk.com">news:6138199@discussion.autodesk.com...
the truth is that most IEC drawings don't contain horizontal symbols. In the
off chance that a user needs to insert a switch or relay contact in a
horizontal orientation it would seem to me that it would make most sense to
locate the actuator portion of the symbol on the top side with INST, LOC, and
TAG above the actuator, thus meaning that the symbol was rotated clockwise.
Then the description attributes and XREF could be located beneath the symbol.
Default locations are only starting points anyway since we can move the
attributes around. Competitive programs don't even have default attributes
other than INST, LOC, and TAG anyway. They locate these next to the actuator
portion of the symbol, left of vertical or on top for horizontal. Any other
attributes must be inserted manually and located as desired on insert. So
deciding on a standard horizontal appearance for IEC symbols is more of a
judgement call to me since the horizontal symbols are most likely to come into
play when performing a library swap from JIC to IEC on a ladder diagram. The
same wouldbe true in reverse if performing a library swap from IEC to JIC,
thus requiring vertically oriented JIC symbols to replace the standard
vertically oriented IEC symbols. So I think what is most important here is
that the IEC vertical and JIC vertical symbols have similar attribute
locations and the IEC horizontal and JIC horizontal symbols have similar
attribute locations, so the library swap feature can function without lots of
cleanup being necessary. With all that being said I think the geometric
portion of the IEC and JIC symbols should also be position similarly. Now to
through a wrench in the works, the Australians typically use a IEC orientation
like IEC. When I was there I saw their version of IEC60617 and it only showed
vertically oriented symbols. But the Australians told me that when they need
horizontallay oriented symbols they usually rotate counter-clockwise. I
actually saw a few drawings that were done that way from one of the companies
down under. They seldom use horizontal though, just like with IEC. This
particular case was an Australian company using a ladder diagram format. I
know this is a lot to bite off and get right, but AcadE just about need to
cover all bases, so Australia can use the symbols as needed and so can Europe
and the U.S. But to me the most important consideration is the library swap,
which most competitive programs cannot even perform at all or do it very
poorly. AutoCAD Electrical has such a powerful ability with its library swap
and I know customers who use this feature extensively. They would be better
served if the horizontal and vertical orientations from library to library are
seemlessly interchangeable.
