AutoCAD Electrical General Discussion
Distinguished Contributor
0 Kudos
Post 1 of 3
Accepted Solution
Naming wire types
151 Views, 2 Replies
08-22-2011 08:44 AM
I am setting up a wire type table.  When I get to multi- colored wire, I am given an error.  We always name our wire
 (W/BK) #12 The error message says I am unable to use that symbol.  Any way around that?
Thanks, April
You can't use a slash.  Computers try to interpret slash as a directory switch.  You can use an underscore.  In the old days layer names could not contain a space so we used underscore to delineate.  I still do out of habit.
Hi.
You could always give the wire layer a wire color label "substitute". In a wire label you can use a slash, and when creating a from/to reports, run the user post "substitue wire color/gauge label text for LAYER names", and your user specified wire color will be used.
THL
*Expert Elite*
293 Kudos
Post 2 of 3
Re: Naming wire types
08-22-2011 09:40 AM in reply to: april_herr
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
*Expert Elite*
150 Kudos
Post 3 of 3
08-22-2011 11:07 AM in reply to: april_herr
Hi.
THL
Trond Hasse Lie
ECAD Consultant, CtrlAltEl
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
