AutoCAD Electrical Forum
Naming wire types
2 REPLIES 2
april_herr
359 Views, 2 Replies
Naming wire types
I am setting up a wire type table.  When I get to multi- colored wire, I am given an error.  We always name our wire
 (W/BK) #12 The error message says I am unable to use that symbol.  Any way around that?
Thanks, April
2 REPLIES 2
You can't use a slash.  Computers try to interpret slash as a directory switch.  You can use an underscore.  In the old days layer names could not contain a space so we used underscore to delineate.  I still do out of habit.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
rhesusminus
in reply to: april_herr
Hi.
You could always give the wire layer a wire color label "substitute". In a wire label you can use a slash, and when creating a from/to reports, run the user post "substitue wire color/gauge label text for LAYER names", and your user specified wire color will be used.
THL
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
”Boost
