AutoCAD Electrical General Discussion
New Member
prithvijitroy
Message 1 of 2 (380 Views)
Multiple standards in Autocad 2013 Electrical
380 Views, 1 Replies
09-03-2012 01:34 AM
I have a number of symbols that I have created that I would like to use with in conjucntion with AS symbols. I have used the symbol creator to create them and have created a library for those symbols with their own MENU.DAT file.
My question is if there's a way to use the two libraries at the same time? when I want to insert an icon using he ICON button, I want to be able to select from AS symbols as well as my own symbols.
I am able to add a submenu onto the AS library folder but I want to avoid doing that if possible.
Prith
dougmcalexander
Message 2 of 2 (326 Views)
Re: Multiple standards in Autocad 2013 Electrical
09-07-2012 10:24 AM in reply to: prithvijitroy
You can accomplish this in a way.  The software will use only one menu at a time, but you can select multiple libraries for the project.  When selecting a symbol, the software looks in the first library in the list for that block name.  If not found, it then searches the next library in the list.  Be sure that your custom symbols library is first in the list.  Any of your symbols that have the same file name as symbols in the stock libraries would be selected first.  For example, if you have a symbol named VCR1 in your custom library and you have the IEC4 library listed second in your library list, the software would insert your version of the relay coil instead of the one from IEC4.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
