Hi, I am desperately seeking wisdom and answers for the following two questions on AutoCAD Elect 2010......
I have tried to be as detailed yet brief,
1: Is it at all possible to have a project as per the example and description detailed below?
i.e. DEMO PROJECT
Drawing 200 a-d sheet 1
Drawing 200 a-d sheet 2
Drawing 200 a-d sheet 3
Drawing 200 a-d sheet 4
Drawing 2200 e-f sheet 1
Drawing 2200 e-f sheet 2
Drawing 22200 g-l sheet 1
Drawing 22200 g-l sheet 2
Drawing 22200 g-l sheet 3
Drawing 22200 g-l sheet 4
Drawing 22200 g-l sheet 5
Drawing 22200 g-l sheet 6
I need to create a project that has up to 12 individual drawing sets with unique drawing numbers, where each individual drawing set may contain anything from 1 to 20 sheets, and i will need to cross reference these sheets using source and destination arrows as components on Drawing 200 a-d sheet 1 are connected to components on Drawing 22200 g-l sheet 5, i have noticed that you can create new drawings with different drawing numbers within a project in ACE my problem is the sheet numbering (it goes up incrementally where i need to stop and restart the numbering sequence with every new drawing set.)
This brings me to my next question...
if the above is not possible then, if i were to create multiple projects for each of the drawing sets (this would solve the sheet numbering issue) does the source and destination function still work on a project to project basis or only drawing to drawing within a project?
Any Help or advice would be greatly appreciated.
Many Thanks
Regards
Simon
